ditchlewis
| posted on 31/7/07 at 01:45 PM |
how is yours fixed (mk indy Pinto)
How have you mounted your alternators?
MK indy Pinto.
Mk suggest mounting the alternator off the water pump housing. i cannot get enough tension on the belt.
what type of alternators are you using? i have a standard ford one prehaps a bit big.
i've seen some nice mountings for a vauhall SBH i think but they are pricey and i've spant enough on this car i think (SWMBO has said
so).
ditch
welderman
| posted on 31/7/07 at 01:47 PM |
mates alternator is the original one, but we made the adjuster bracket to suit and ran the engine whikst we sanded the fins down .
Works a treat.
Thank's, Joe
I don't stalk people
peterparsons
| posted on 31/7/07 at 02:06 PM |
Mine's a standard one, just bought a shorter belt
jabbahutt
| posted on 31/7/07 at 02:26 PM |
for some reason I couldn't fit my standard alternator as it clashed with the angled chassis rail.
fitted a Nippon Denso alternator off a Micra with a home made bracket from some angle iron. there are a few photos in my archive though not that
clear.
DarrenW
| posted on 31/7/07 at 03:14 PM |
Here is mine. Micra alternator, std ointo top arm from custom bracket. Belt is Halfords HBH850a iirc.
DarrenW
| posted on 31/7/07 at 03:15 PM |
And the custom bottom bracket (Mac#1 supplied).
bob
| posted on 31/7/07 at 07:11 PM |
Mine was pretty much exactly the same as darrens, i used a bedford rascal/suzuki SJ alternator.
I have had a look in the cave but just cant find the old alt bracket anywhere,i'm off shift from thurs so i'll have a dig around.
The Baron
| posted on 31/7/07 at 07:37 PM |
The same solution for me!!!
cheers,
The Baron
ditchlewis
| posted on 1/8/07 at 07:28 AM |
many many thanks.
i think the MK solution has a problem... it means that the rear of the alternator is not located properly    and allows the alternator to
wobble. i've tried to restrain the rear but your solutions are better.
i put on a shorter belt which allows more tension but the alternator is not straight (parallel to the block)
ditch
DarrenW
| posted on 1/8/07 at 08:02 AM |
Im pretty sure MK owners have used the Mac#1 bracket set to good effect before.
