Author: Subject: Wiring LED Lights
907
posted on 2/8/07 at 05:31 PM Reply With Quote
Wiring LED Lights
Hi All,
I bought these LED rear light units from the SVC stand at Newark show and now wish to wire them up.
I'm a complete numpty when it comes to electrics but I've had a stab at what I think the way to wire them is. (see pic)
Because the white wire goes to both sides I assume that's the earth????
The red and the black I may have the wrong way round. Brake and rear light????
Yellow goes in the indicator side but it comes with a resistor (??) which I assume I should join to the yellow,
and the other end of the gold thingy should go to the flasher stalk???
Can the resistor be wired the wrong way? i.e. does it have an in and out?
Sorry if this is obvious to everyone else but it's all Greek to me.
Many thanks
ironside
posted on 2/8/07 at 05:39 PM Reply With Quote
The resistor is to protect the LEDs, so I would've thought that it would have to go on the ground lead to protect all the sets of LEDs in the cluster. Didn't it come with any instructions?
It doesn't matter which way round you have the resistor though.
SeaBass
posted on 2/8/07 at 05:53 PM Reply With Quote
Personally I thought the resistor was just to give enough load on the indicator circuit... this will make the indicators flash at the correct speed. Most vehicle LED units have resistors built in to limit current.
907
posted on 2/8/07 at 05:58 PM Reply With Quote
I have assumed that it is to fool the flasher unit into thinking it's a 21w bulb???
No distructions, I mean instructions.
Hang on, I might have been right the first time.
Paul G
ironside
posted on 2/8/07 at 06:07 PM Reply With Quote
That makes sense resistor on flasher circuit only then.
posted on 2/8/07 at 06:09 PM Reply With Quote
I would suggest a conversation with SVC - Steve himself posts here, so should be able to give guidance.
owelly
posted on 2/8/07 at 06:16 PM Reply With Quote
I would also say that all the LEDs will be 12v ones and the resistors are just for the indicator LEDs tomake them flash at the correct speed.
http://www.ppcmag.co.uk
posted on 2/8/07 at 06:51 PM Reply With Quote
The resistor is VERY unlikely to be designed to be in the negative for both LEDs. If so the voltage to the LEDs would depend upon whether one or both lights were on. IE if you had the brake light on the indicator would effect the brake light brightness which is possibly an MOT fail...
The resistor is much more likely to be to get the flasher unit wattage up to normal speed.
Check with SVC though. If you hook them on wrong (Eg if they're supposed to have series resistors) and blow them I doubt SVC will give you some new ones...
...though not giving instructions sucks a bit!
907
posted on 2/8/07 at 07:10 PM Reply With Quote
I phoned SVC at 1.45
Got an answer phone, left a message.
No answer, so I posted on here at 6.30.
Will try again tomorrow.
Thanks for the replies.
Paul G
They gave me the resistors when I bought the lights, so they are the right ones.
[Edited on 2/8/07 by 907]
Jon Ison
posted on 2/8/07 at 07:18 PM Reply With Quote
you could do away with the resistor altogether and get a flasher suitable for leds, just takes the resistor out of the equation and one less thing to keep dry or go wrong, that's the route I took ?
rusty
posted on 2/8/07 at 07:22 PM Reply With Quote
I would think the resistor would go in parallel with the indicator, to, as said fool the flasher unit.
907
posted on 2/8/07 at 08:33 PM Reply With Quote
Are all your indicators LED's Jon?
I have bulbs in the fronts and in the side repeaters.
Paul G
jkarran
posted on 2/8/07 at 09:34 PM Reply With Quote
The white will be GND (0V) the three colours will be your +ve feeds to your three lights. The resistor (based on it's size) looks like an extra load to keep mechanical flasher units in time, wire it between yellow and white.
jk
designer
posted on 3/8/07 at 01:53 PM Reply With Quote
The resistor is to fit in the live circuit. You can't just wire LED's like bulbs.
907
posted on 3/8/07 at 05:31 PM Reply With Quote
Thanks for all the replies.
I've phoned again and emailed but haven't had a reply yet.
So does this look right?
(blue = the white wire)
posted on 3/8/07 at 06:22 PM Reply With Quote
Paul I think the resistor should go in the yellow feed to the L.E.D. , not one side to earth .
omega 24 v6
posted on 3/8/07 at 06:40 PM Reply With Quote
As a guy who fits Leds to trucks on a regular basis the resistor always goes in the indicator line in parrallel as has been said already. It is to create a dummy load for the flasher unit as said by others and yes your diagram looks fine.
[Edited on 3/8/07 by omega 24 v6]
907
posted on 3/8/07 at 06:48 PM Reply With Quote
jk seems to think between feed & earth if I understand him correctly.
NOT like this ???? (see below)
I wish I had a brain
omega 24 v6
posted on 3/8/07 at 07:06 PM Reply With Quote
If you think about it and it needed to be in series they'd have to supply you with 3 resistors per light.
907
posted on 3/8/07 at 07:21 PM Reply With Quote
Omega, I think your right.
If you join unequal wattage bulbs in series only the lower wattage one lights.
(er, I think)
I'll go for it.
Thanks a lot.
Paul G
907
posted on 5/8/07 at 08:08 PM Reply With Quote
I received an email from Steve at SVC today.
He confirms that the resistor is wired between the power feed to the indicator (yellow) and earth (white).
He suggests that it is fitted at the dash end of the wire, not near the light itself.
Seems good advice.
Many thanks to ALL who contributed to this thread.
Cheers chaps
Paul G
tks
posted on 5/8/07 at 08:14 PM Reply With Quote
Seems good advice.
Cheers chaps
Paul G
he suggest that because in that way the "power" circuit is as close possible to the battery.
in series won't make anydifference because the resistance is that low that the leds will lit up normally (they have a higher resistance)
Tks
