Author: Subject: EDIS Position
posted on 3/8/07 at 12:35 PM Reply With Quote
EDIS Position
OK, before I go and solder the plugs onto the pip and saw wires I intend to put the EDIS module right next to the Megajolt unit.
Is this OK, just wondering as Ford put them on the inside of the wing. Does the EDIS get hot and need to be awy from the Megajolt unit??
graememk
posted on 3/8/07 at 12:57 PM Reply With Quote
mine is on the bulk head engine side but i'm part way through a re wire and i think it will keep cooler on the inside so thats where i'm putting it about 4" from my megawottsits.
andyace
posted on 3/8/07 at 02:18 PM Reply With Quote
I dont think it does as the megajolt system I am buying (www.kimmins.info) has the EDIS unit in the same unit as the megajolt unit.
COREdevelopments
posted on 3/8/07 at 03:15 PM Reply With Quote
i fitted mine in the passenger footwell, only last night.
dave1888
posted on 3/8/07 at 04:48 PM Reply With Quote
I put the edis and megajolt in the same ali box thats fitted to the to the bulkhead. I might drill some holes for cool air to get in though.
cs3tcr
posted on 4/8/07 at 03:36 AM Reply With Quote
I've got my EDIS on the engine side of the bulkhead, with the MegaJolt in the passenger side footwell. Ford fitted the EDIS under the hood, so i can handle heat fairly well. The MegaJolt, well i dont think i would want to subject it to much heat.
