Author: Subject: coil pack 2003 bmw 1800ti
thunderace
posted on 14/8/07 at 02:47 PM Reply With Quote
is it straight swap of coil pack or do i need to take it to a bmw garage to get them to restet the ecu ?
i dont want to swap it to find that my mates car will not start after me changing his coil pack as he was told it would need to go on a laptop before starting.
posted on 14/8/07 at 06:34 PM Reply With Quote
If is the same coil packs Rover adopted under BMW control -- which don't need introduced to the ECU. --- but knowing BMW the same guys who sell BMW Minis without the special key to change a wheel!!!!!!
Of course if a fault code is logged it will need cleared -- via the EOBD connector.
Be aware that it is really a good idea to change the "leads" rubber and plugs at the same time as a coil pack -- a lot of coil pack failures are caused by plug & plug lead HT faults.
With the Rovers a lot of HT problems are solved by fitting new plugs gapped narrower than the spec. Setting the gap to 0.8mm (as Rover used to use) stops a lot of low speed misfires that develops as the plugs age.
[Edited on 14/8/07 by britishtrident]
posted on 14/8/07 at 07:12 PM Reply With Quote
Quick search revels this is a major BMW problem, as with PGA group cars it can cause ECU burn out.
Root cause is probably excessive HT voltage required by the spark plug causing the insulation in the coil pack to fail.
BMW have been recommending plug changes at 100,000 mile intervals ---- !!!!!!
I thought Rover were bad expecting 60,000 miles out a set of plugs.
With Rovers we learned the hard way and now change the plugs at 30,000 using only the specific OEM plugs and gap them to the narrower gap.
