iiyama
posted on 21/8/07 at 07:17 PM |
Hazards/indicators and savage
Done some searches but cant find what Im looking for.
Savage hazard switch, indicators and relays. How? Do I need two relays, ie a flasher and a hazard? Or can I use one? Is one way better then
another? Diodes required or not? Help!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
bigrich
posted on 21/8/07 at 09:22 PM |
you will deffinately require diodes, you can get it to work with one relay but it will mean that the indicators will work with ignition off. i
personally preferred 2 relays to seperate the systems
I used 2 relays 2 diodes a on/off/on switch for the indicators and a savage switch for hazzards
iiyama
posted on 22/8/07 at 05:59 AM |
There are different relays though. Seen some electronic jobs that appear to do both hazards and flashers. The electro-mechanical types seem to do one
job so two are required.
Any pointers to a circuit diagram?? Pretty please Especially a diagram with the pin out numbers of a Savage switch!!!
