Author: Subject: warning colours
iiyama
posted on 22/8/07 at 08:22 PM Reply With Quote
warning colours
Are there specific colours required for fog and hazard warning lights for SVA?? Can I use the indicator warnings on the bike clocks for the hazard warning?
Ta!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
posted on 22/8/07 at 08:25 PM Reply With Quote
Most hazard warning lights I've seen are red when associated with the hazard switch itself. However I believe that having the 2 indicator lamps (usually green) on the dash flashing in time with the hazards is enough - but don't quote me.
Most fog lamp warning lights I've seen on tin-tops have been amber. I don't think it matters as long as it's properly labelled, or has the correct symbol on it.
HTH
[Edited on 22/8/07 by David Jenkins]
graememk
posted on 22/8/07 at 10:05 PM Reply With Quote
my hazzards only flash the green arrows on the bright 6 and passed sva ok and my fog is a savage switch
Avoneer
posted on 23/8/07 at 06:30 AM Reply With Quote
Yes, you can use the indicators as Hazard warning lights.
I think the only one that has to be colour coded and marked is the low fluid/hand brake warning lamp.
Pat...
NeilP
posted on 23/8/07 at 07:10 AM Reply With Quote
For FOG it's just a visual indication - I'm using a savage switch which lights up in blue....
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
iiyama
posted on 24/8/07 at 06:19 PM Reply With Quote
Cool guys, thanks.
Regards the brake fluid/handbrake then I guess this has to be red?
posted on 24/8/07 at 06:26 PM Reply With Quote
Yes, and it also has to have the correct symbol on it - a bit like (!) - but slightly more complicated!
