phil m
posted on 8/9/03 at 06:57 PM |
temp gauge
x-flow engine with origional gauges-------
the temp sender is new but the gauge will not read when connected up properly . Only time it moves is when not earthed ,then it goes off the scale.
Other parts of gauges work--rev counter etc
Any ideas, or is the gauge faulty ????
Hopefully , Phil
Stu16v
posted on 8/9/03 at 08:31 PM |
Has the guage ever worked in your car, or is it a new build? Sounds like either the wiring to the guage is wrong or it is faulty.
HTH Stu.
phil m
posted on 8/9/03 at 08:46 PM |
never seen it work properly, but the origional escort loom , gauges ets are being used . Maybe it's knackered as you say !
