Author: Subject: Wiring Help
Tinks1
posted on 28/8/07 at 08:57 AM Reply With Quote
Wiring Help
Hi, I have spent all weekend wiring in the ECU for my MK with 2.0L Pinto with Carbs and have now connected everything , but I notice on the Vikki Green loom there are 2 wires one white and one white/black that the wiring diagram states are the important wires for wiring up various ignition systems.
What do I do with these wires..
John
posted on 28/8/07 at 12:04 PM Reply With Quote
These wires should connect to your coil.
When you say ECU do you mean the ignition amplifier (Black plastic box mounted on an alloy plate with a 7 pin plug at the bottom and Motorcraft moulded on the side)?
If so and IIRC 2 of the wired from the ignition amp need to be spliced into the wires you refer to to drive the coil.
HTH
Tinks1
posted on 28/8/07 at 01:51 PM Reply With Quote
NO, it's the ECU that is about 5" square and 1" thick with a 24 way connector which goes to a stepper motor on the carb, a 3 pin plug to distributor, 3 relays, and the coil + suppressors
John
posted on 28/8/07 at 03:07 PM Reply With Quote
Can't help with that one I'm afraid.
I had the same st-up on my donor car but after looking at the installation I ditched it in favour of the earlier inductive discharge set-up with the ignition amplifier, 2 wire dizzy and DGV carb.
