steveyb
posted on 28/8/07 at 12:13 PM |
zetec wiring
is thre any way of wiring a zetec engine an easy way?
i converted my mk4 escort from cvh
to 1.8 zetec i have it running but i have all the wiring layin inbeside the engine,
is there any way i could wire it so that i dont have to take all the wires through the bulkhead?
saigonij
posted on 28/8/07 at 12:32 PM |
you could leave the ECU in the engine bay, but ford ECU's were designed ot be in the cabin, so it might not do it any good..
if you do choose this way, then there are a few wires you need to connect up...
20, 40 and 60 are earths. then i think 22 is the fuel pump relay earth. you will also need an ignition live.
if you have the loom in one piece still, then at one point you will have a 8 way connector - this helps. if you do let me know and ill talk you though
the next bit.
steveyb
posted on 30/8/07 at 04:42 PM |
yes i have the full loom,
i intend putting the ecu inside the car!
yes the connecters are in the loom and i have the wires running to the fuel pump inside the tank.
thanks
[Edited on 30/8/07 by steveyb]
