jabbahutt
posted on 29/8/07 at 08:01 AM |
oil pressure sender and switch
Morning
Having fun at the moment getting oil pressure to register before starting the engine.
If the sender and pressure switch are earthed through the block and PTFE tape is fitted would you expect the gauge to read zero even if pressure was
present.
Stupidly I've fitted tape and wondered whether you'd get zero or full deflection if earth wasn't good.
bbwales
posted on 29/8/07 at 08:04 AM |
If the sender isn't earthing it will be registering as an open circuit and so will show no deflection.
HTH
Bob
2b_pablo
posted on 29/8/07 at 08:08 AM |
check there isnt tape over the front of the sender hole.
ash_hammond
posted on 29/8/07 at 09:39 AM |
As a manual check take the rocker cover off the top of the engine and see if oil is coming out of the sprayer bar over the cam, this will give you an
indication to weither ur oil pump is working.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
RazMan
posted on 29/8/07 at 09:45 AM |
You can always check for continuity between the sender body and earth with a multimeter. If you don't get a reading then remove the ptfe tape.
Raz
2b_pablo
posted on 29/8/07 at 10:01 AM |
the ptfe tape will tear at the outer edge of the threads tho, unless there are massive amounts of ptfe tape in I cant see that you would isolate the
sender.
posted on 29/8/07 at 11:00 AM |
why the need for ptfe tape?
2b_pablo
posted on 29/8/07 at 11:07 AM |
mine weeped a little with no ptfe tape.
posted on 29/8/07 at 11:22 AM |
Same here. Bit of tape did the job but when you remove these senders the tape is usually ripped through, earthing the sender to the block.
If for whatever reason it's impossible to stop the tape isolating the sender you could attach a seperate earth to the sender body (something
like a tabbed washer would be appropriate).
