Author: Subject: Fitting fan sensor outside tubes?
tegwin
posted on 1/9/07 at 10:42 AM Reply With Quote
I have a cappilary fan switch setup and have tried to fit the probe into the top radiator hose as it says in the rather poor instructions....But under pressure it just leaks out of the hose where the sensor goes in, even with the jubilee clip tight...
I have an inline filler neck like this one:
Could I use some kind of heat conductive compound and mount the sensor on the outside of the filler housing tube and then wrap it in insulation?...Would just have to hope there is enough adjustment in the sensor to compensate for the heatloss caused by the metal...
Is there any other way of fitting these cappilary type senders inside pipes without it pissing out everywhere?
posted on 1/9/07 at 11:19 AM Reply With Quote
On some temperature sensor kits (bulb type) you get a rubber sleeve that fits over the connector tube before you put the sensor in place, radiator hose etc. The rubber sleeve has enough give in it to give a good seal even when the sensor tube is in place.
tegwin
posted on 1/9/07 at 11:21 AM Reply With Quote
I do have the rubber sleeve that would do the job, but there is no way on this planet you would be able to slide the top hose over the top of it if its sat on the radiator inlet!
RazMan
posted on 1/9/07 at 01:42 PM Reply With Quote
I've got a similar setup with my Davies Craig pump controller. It leaked badly until I discovered the secret - a dab of PU adhesive around the wire where it touches the hose.
Raz
