Vindi_andy
posted on 3/9/07 at 11:08 AM |
denso alternator
I have a size issue with my OEM alternator fitted to my Twincam ie its too big ( how many times have i heard that )
I have seen a small denso alt listed in demon tweeks (100 mm) and was wondering if anyone knew if these will fit a twink
ned
posted on 3/9/07 at 12:25 PM |
I have a little denso alternator on my twincam vauxhall if thats of any help..?!
Not quite sure what you're asking though and you don't mention what engine you have.
Ned.
beware, I've got yellow skin
Vindi_andy
posted on 3/9/07 at 03:14 PM |
ford 2.0 efi twincam is the engine was wondering if the mounting is correct for the ford bracket
Normally post on a ford owners website so the twincam name is immediately recognised forgot there were different types of twincam that can be used in
kitcars
[Edited on 3/9/07 by Vindi_andy]
ned
posted on 3/9/07 at 03:39 PM |
I have no idea what mounting the ford bracket has, regardless it shouldn't be too hard to make it fit, you might need a different length belt
(vbelt?) from your local motor factors and might have to space the alternator with washers to get the pulleys to line up, so assuming the pivot bolt
is the same size not a difficult job at all. It is unlikely to be a direct swap though if that's what you're after?
Ned.
