Author: Subject: Temperature switch
Mark Allanson
posted on 8/9/07 at 01:10 PM Reply With Quote
Temperature switch
I want to fit a small bilge blower to my engine bay to cool the car down when parked up after a drive. I think having it set to about 50°C would be an ideal temp for it to cut in (or cut out below).
Has anyone got any ideas how to make/buy a switch/thermostat to achieve this? Forgot to mention it is 3A 12v Rescued attachment bilge blower.jpg
posted on 8/9/07 at 01:11 PM Reply With Quote
http://www.maplin.co.uk/Module.aspx?ModuleNo=220003&doy=8m9&C=SO&U=strat15
too easy
£6 from Maplins...
NeilP
posted on 8/9/07 at 01:15 PM Reply With Quote
Have you got a thermostatic switch on your rad fan? If you do then wire you fan to permament live - even without the water pump running you get a convective flow which is really good a quickly cooling the engine.
Mine will run for 2-3 mins after a serious threp and it gets the whole engine cooled down nicely.
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 8/9/07 at 01:44 PM Reply With Quote
I must admit that that was my first thought!
Why bother with the bilge pump when there's a perfectly good temperatre switch and fan at the front of the car? and adding the bilge pump + switch will add to the weight of the car.....
Mark Allanson
The maplins PCB looks good - unfortunately they are out of stock
My rad fan only cuts in when VERY hot and will only run after the ignition switched off for a few seconds.
I had thought of fitting a rad fan switch very close to the exhaust manifold, but do they only work with water?
posted on 8/9/07 at 01:47 PM Reply With Quote
I get a lot of rude remarks about my rad fan - it goes on for 5 or 10 minutes after shut-down!
Strangely, it sometimes takes 1 minute before it starts... probably the water gets heated up by some hot-spot, then circulates round to the fan...
posted on 8/9/07 at 01:54 PM Reply With Quote
http://www.circuit-innovations.co.uk/thermsw.html
posted on 8/9/07 at 01:59 PM Reply With Quote
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=31698&doy=8m9
but the max switch temp is 30degC.
Changing the NTC thermistor or the adjusting potentiometer might make the range greater.
posted on 8/9/07 at 02:07 PM Reply With Quote
Actually, I've just had a look at the manual for that module. You could adjust the range many ways. Simplest would just to put a resistor in series with the thermistor. That would move the switching temperature into a high temperature for the same threshold resistances....
Mark Allanson
posted on 8/9/07 at 02:59 PM Reply With Quote
Would it be safe to run a 3A motor with a 3A controller?
posted on 8/9/07 at 03:08 PM Reply With Quote
Pushing your luck, I think - most electric motors take a fair bit of extra current when starting. It depends whether the motor is 3A constant while running, or max 3A.
Mark Allanson
posted on 8/9/07 at 03:42 PM Reply With Quote
I just found an old Nissan Micra rad switch and tapped in into my exhaust heat shield - It works!!
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 8/9/07 at 09:58 PM Reply With Quote
Mine does exactly the same!
A great piece of engineering!
posted on 9/9/07 at 10:10 AM Reply With Quote
Why not change the fan switch for one with a more suitable setting? Check out your local motor factors, the operating temperatures are engraved on the brass body. Also found some vents in the bonnet helped greatly. Like David my fan runs for ages after stopping and drops the under bonnet temperature a treat
