SALAD
| posted on 20/9/07 at 11:22 AM |
What are these?
EDIS4 on the left obviously but what are the others? They have a vacuum take off type thingy which the EDIS4 doesn't.
They have '89FB-12A297-BB' on them.
  EDIS4 & ?
Ketchup
| posted on 20/9/07 at 11:45 AM |
they are ignition control units, similar to the edis 4 but advance is contolled with the vac connection, you could use one to run a zetec for example
instead of using a megajolt as all the spark control is built into that "esc" unit
| posted on 20/9/07 at 11:48 AM |
ESC = Electronic Spark Control
According to Mr Haynes Manual there are several iterations of this system which seems to have been introduced to replace the older Inductive Discharge
system.
SALAD
| posted on 20/9/07 at 12:09 PM |
So no good for running megajolt with then.... as I thought, but worth asking first!
graememk
| posted on 20/9/07 at 03:14 PM |
have a u2u with big_wasa he makes up little units with them
