Mole
posted on 22/9/07 at 02:38 PM |
Micra Alternator Bracket
Any one any idea how to remove the orginal bracket from a micra alternator. Preferably not using an angle grinder.
posted on 22/9/07 at 03:03 PM |
Plasma torch?
I've got a copy of the Haynes manual in the garage for the Micra, let me know if you need any pages whipping onto the scanner....
Sounds like you're modifiying / butchering the alternator though which probably won't be
Mole
posted on 22/9/07 at 03:51 PM |
There seems to be some sort of insert with a slot cut in it in that hold it on but it doesn't look like it would be easy to compress. I may
have to resort to drilling it out.
I have a feeling it won't be in the haynes manual either.
[Edited on 22/9/07 by Mole]
Chippy
posted on 22/9/07 at 10:15 PM |
Don't know about Micra alternators, but by the sound of what your talking about, it's the adjustable spacer, that ensures a good fit to
the bracket. If correct it would be in the back hole, where the mounting bolt goes through, to release it put a socket over the insert, and just tap
the alternator body towards the front, that "should" give you the clearance to get it of. HTH Ray
Mole
posted on 23/9/07 at 01:07 PM |
Cheers Chippy that worked a treat
