Author: Subject: viento wiring diagram
kenton
posted on 24/9/07 at 08:26 PM Reply With Quote
Hi all,
Im about to sort out all the wires behind the dash and i dont have a wiring diagram. Its a luego loom with relay pack. Is there a diagram available?
Thanks kenton
NeilP
posted on 24/9/07 at 09:24 PM Reply With Quote
Kenton, There was never a diagram as such just some (dubious) written instructions - I'll see if I can dig out and scan in - In the meantime you should have everything on the loom labelled as supplied so you should be able to lay out over the chassis and do trial fit etc?...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
kenton
posted on 24/9/07 at 09:32 PM Reply With Quote
Thanks,
yes it was labled, the rest of the loom is done its only the connections behind the dash.
I was hoping not to have to go through them with a meter!
kenton
