pmw
| posted on 26/9/07 at 06:05 PM |
Cable binding
Does anyone know what the cable binding is called thats like a webbing. You can put a load of cables through it like heat shrink, but this looks a bit
more professional. I've attached a pic of the closest thing I've found.
Sorry to be so vague, I "think" I've heard it called ringale sleeving, but web searches don't come up with anything ?
MkIndy7
| posted on 26/9/07 at 06:25 PM |
Split or Convoluted tubing
http://stores.ebay.co.uk/Auto-Performance-Silicone-Hoses_Convoluted-Tubing_W0QQcolZ4QQdirZ1QQfsubZ12112862QQftidZ2QQtZkm
They do mixed diameter packs that are very useful.
I've used them before very products and prices!,
Not sure where in West Yorkshire you are, but if you either ring them or serch their Ebay shop their address is on there and if you speek to them
they'll usually let you collect.. makes the prices even better
Its pretty close to Kirkstall Abbey in Leeds alot of their other stuff is resaonable prices as well, Electrical Crimps, Fuel pipe and Clips etc.
iank
| posted on 26/9/07 at 06:55 PM |
The stuff in the photo is simply called "Expandable Braided Polyester Sleeving" by Polevolt (page 8 of their catalogue)
They also sell the more commonly chosen convoluted tube type.
http://www.polevolt.co.uk
Anonymous
r1_pete
| posted on 26/9/07 at 07:57 PM |
Vehicle wiring products stock it and everything else you could need for wiring.
www.vehicle-wiring-products.co.uk
[Edited on 26/9/07 by r1_pete]
ReMan
| posted on 26/9/07 at 09:05 PM |
Only thing wrong with it is the frayed ends.
To avoid you need to plan you heatshrink carefully before fitting connectors
iank
| posted on 27/9/07 at 06:34 AM |
The other way of handling it is to use a soldering iron to melt the end and then fold it back in on itself if it needs to look pretty (polo neck
style)
The advantage over convoluted tube is it's a lot more flexible.
Oh Premier also sell it
linky
I'm sure RS and Farnell will also carry it.
Anonymous
Vindi_andy
| posted on 28/9/07 at 12:41 PM |
A heatgun works just as well to fuse the ends however the nylon braid stuff obviously cant be used near anything that might get hot as it will melt
Used to use this at a previous job for making up wiring harnesses
Macbeast
| posted on 28/9/07 at 01:41 PM |
Really wouldn't use it in a car. The open weave would soak up oily dirt. I've used it in rack wiring and it's horrible stuff.
