Findlay234
posted on 19/10/07 at 03:55 PM |
SVA and insulating tape.
Is this a no no, and where best can i source other tape to do the job???
Bluemoon
posted on 19/10/07 at 03:58 PM |
Depends on what it is for. I do not use insulation tape for insulating as it always comes loose after a time! O.k for wraping loom (better to use loom
tape though none sticky stuff).. For insulating terminals I use heatshrink.
Dan
pewe
posted on 19/10/07 at 04:11 PM |
Self-amalgamating tape and heat shrink from the likes of Maplins is OK for loom wrapping or you can buy loom tape from the likes of Vehicle Wiring
Products. Cheers, Pewe
smart51
posted on 19/10/07 at 04:27 PM |
I used it for rewinding parts of the loom that I'd changed and had no questions asked.
Macbeast
posted on 19/10/07 at 04:30 PM |
I wouldn't use insulating tape . After a while it gets either hard and brittle or horribly sticky. Also I don't think under-bonnet
temperatures would do it much good
RazMan
posted on 19/10/07 at 04:59 PM |
Some of the best quality tapes are pretty good and will last the distance. You get what you pay for so give eBay a miss and order from an electrical
supply company and get the proper stuff.
Having said that I always use heatshrink where possible - that is as permanent as you want it to be.
Raz
SeaBass
posted on 19/10/07 at 06:10 PM |
I'll second loom wrapping tape - with some heat shrink on the ends to keep it tidy...
worX
posted on 19/10/07 at 08:53 PM |
I'd second loom tape aswell, although the last lot of tape I bought from an engineering/e;ectrical place seemed to be a lot better than the
norm!
Shamrock GS
posted on 20/10/07 at 07:28 AM |
I was just SVAd lat the beginning of the month and the tester said her didn't like to see acres of insulating tape - preferred proper loom tape
and self-amalg. His view was that insulating tape pointed to 'bodging'
Gary
Sun Tzu, The Art of War
