robinj66
posted on 26/10/07 at 02:22 PM |
Sealed Beam Headlights
I have to attach the sidelight bulb (which is set in it's own little cone reflector) to the back of the sealed beam unit. It was originalyy
attached with some sort of mastic-type stuff long powdered and gone.
Any suggestions as to what to use - will sikaflex type stuff (pu or silicone) withstand the heat? (I've no idea how hot the rear of seled beam
lights get)
RoadkillUK
posted on 26/10/07 at 02:26 PM |
I used a hot glue gun to fix mine on, 3 years on the road and they are still on
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 26/10/07 at 02:41 PM |
sealed beam? as in 7 inch? as used on land rovers, mini etc?
bin them and fit halogens; trust me, they are sh&te; only advantage is you can wade in them nad they donl;t fill with water.mud. light output is
patheic.
I have a piar of sealed beam units for free as that is what I did.
robinj66
posted on 26/10/07 at 02:58 PM |
I'm only using them to get through the SVA as they have an E-mark
[Edited on 26/10/07 by robinj66]
posted on 26/10/07 at 03:18 PM |
ok, i'll let you off then, but just this once mind
posted on 26/10/07 at 03:39 PM |
Actually round sealed beams particularly if they are the old Biritish/American pattern aren't that bad --- a lot better than euro pattern
tungsten bulb head lights.
robinj66
posted on 26/10/07 at 06:24 PM |
Glue gun worked fine
It's a tool that I've had for a while but never used - just kept in a draw
Now christened...
