donut
| posted on 1/11/07 at 10:19 AM |
Escort [locost] Premier wiring loom to sierra column switches
How easy is it to wire up the escort locost premier loom to the Sierra stalk switches? Does anyone have a diagram of what each stalk connector does?
Duncan_P
| posted on 1/11/07 at 10:30 AM |
Im in the process of doing this at the moment, have actually found it pretty easy. Even though I have life difficult for myself by having stalks from
different years on each side
I just used a sierra wiring diagram coupled with the PW instructions. One tip I have is that if take the wiring plugs off the stalks and look
carefully inside it has the terminal number printed into the plastic beside the terminal. This really helped to clarify that my assumption based on
colour was correct.
Unfortunately my scanner is playing silly buggers at the moment so i cant offer to scan in my wiring diagrams from the workshop manuals for you.
Paul (Notts)
| posted on 1/11/07 at 10:35 AM |
found these when I was doing the switches - long time ago so not sure who did them or how accurate they are.. ( NB there are two types of switches one
is a switched earth the other is a switched live to do with the bg83 number on switch.)
Paul (Notts)
| posted on 1/11/07 at 10:36 AM |
other
donut
| posted on 1/11/07 at 11:41 AM |
GREAT!! thanks chaps, much apreciated.
