Author: Subject: Electric Heater
cerbera
posted on 2/11/07 at 12:09 PM Reply With Quote
Electric Heater
Has anybody fitted an electric heater to keep their feet/legs warm during the colder months?
If so, are they any good and where did you buy it from and is it an easy install?
TA
blakep82
posted on 2/11/07 at 12:24 PM Reply With Quote
i haven't, but NFauto have them, and they're cheaper than anywhere else i've seen
________________________
posted on 2/11/07 at 12:53 PM Reply With Quote
Be aware that the low wattage ones don't do much!!! If you consider how many kW most engines give out as heat its not suprising a 5A heater isn't going to do much when it's chilly outside!!
matt_claydon
posted on 2/11/07 at 12:59 PM Reply With Quote
The coolant-fed heater NFAuto sell is 4500 watts (twice the average mains fan heater). 5 Amps at 12v is 60 watts (think light bulb!).
My conclusion - don't even bother, they are a con! Better bet would be to cut a hole in the firewall
posted on 2/11/07 at 01:14 PM Reply With Quote
They aren't a con but don't put out much heat.
I have one for pre-defrosting my tin top, on really cold mornings I leave on for 15 minutes before I go out.
If you really want simple cockpit heating just plumb an old heater matrix into the by-pass circuit of the cooling system.
posted on 2/11/07 at 01:18 PM Reply With Quote
Eh???
4500W is 375A at 12v!!!!
That's one bloody big alternator required!!!
Even 37.5A would kill my BEC alternator
matt_claydon
posted on 2/11/07 at 02:03 PM Reply With Quote
Originally posted by BenB
Eh???
Suggest you re-read what I said
posted on 2/11/07 at 02:08 PM Reply With Quote
Eh? So they work out the heat output of a coolant-powered heater as Watts? I suppose- why not! Fair enough... Me talking testicles as usual then...
Shows why an electric one is going to struggle to keep up
RazMan
posted on 2/11/07 at 02:39 PM Reply With Quote
I've got one of these and I must say they work quite well. 4.5kW may sound like overkill but its just enough to keep my car toasty in cold weather with the roof on. You can even feel it when the roof is off but I doubt you will even notice anything with less power in an open car. Those demisters will be a waste of money imo.
You will be much better off plumbing something into the megawatt heater you already installed under the bonnet
[Edited on 2-11-07 by RazMan]
Raz
cerbera
posted on 2/11/07 at 06:03 PM Reply With Quote
Cheers for the replies guys.
