twybrow
posted on 23/11/07 at 08:26 AM |
Wiring for cigarette lighter
Which way around do you wire in a cigarette lighter (12v supply)? I don't want anything I plug in to run backwards! Is it +ve pin is the centre
and -ve to the casing?
rgrs
posted on 23/11/07 at 08:28 AM |
Yes
rallyingden
ElecTrickery
Yep You have it right
Centre +ve
Outer ? Case -ve
RD
twybrow
posted on 23/11/07 at 08:46 AM |
Brilliant, thanks guys - and very responsive for early Friday morning. Well done, you go to the top of the class!
Here, you can have a smiley too!
[Edited on 23/11/07 by twybrow]
Macbeast
posted on 23/11/07 at 08:50 AM |
Bugger!
I thought it was Saturday
Oh well
mookaloid
posted on 23/11/07 at 10:07 AM |
quote: Originally posted by Macbeast
Bugger!
Oh well
I know how you feel
wilkingj
posted on 23/11/07 at 10:14 AM |
Make sure you wire it with at least 16Amp wire, and put a 15 Amp fuse in line as well.
The current (Amps) spec for a Lighter socket is quite high, so ensure the wiring all the way back to the battery is the right size (and fused).
You dont want a fire due to using too thinner wire with a too big a fuse
Best Regards
Geoff
http://www.v8viento.co.uk
robertst
posted on 23/11/07 at 12:06 PM |
cigarette lighter on a locost?! thats quite a luxury for this car. adds weight, just take a lighter with you :p i'd rather have a radio.
twybrow
posted on 23/11/07 at 12:38 PM |
The feeling is, I am unlikely to be able to take the car away for long trips, if I don't have the ability to charge a phone or TomTom etc.
Don't worry - that is by far the most luxury my car is having. I traded cigarette lighter for windscreen - seemed like a good trade!
Neil P
posted on 23/11/07 at 12:43 PM |
How do you tell whether your cigarette lighter is running backwards?
Neil
twybrow
posted on 23/11/07 at 01:38 PM |
It cools rather than burns the cigarette.
posted on 23/11/07 at 01:47 PM |
The SVA man said mine was the first Locost he's seen with a lighter socket (though obviously being anti-smoking I call it a 12v accessory socket
Useful for charging the mobile whilst on a blat (even I don't hear it ringing!!!)...
posted on 23/11/07 at 01:50 PM |
My socket isn't a lighter one, even though you could plug one in - it's got a flip-up cover that says '12v 10A' on it!
My trickly charger ( ) is usually plugged into it when the car's in the garage...
This discussion reminds me of a motorcyclist I saw in Austria - zooming along at 60-ish mph, smoking a pipe, and leaving occasional clouds of pipe
smoke behind him!
[Edited on 23/11/07 by David Jenkins]
_Aero_
posted on 23/11/07 at 05:50 PM |
I have wired outlets such as this with only a 1 amp fuse - it's not intended for an output only for trickle charger which are genrally
150-300MA. As Bike engines/batteries are not meant to be drawn from without being powered.
My 2p
