Author: Subject: Edis 4 problems
dave1888
posted on 24/11/07 at 04:13 PM Reply With Quote
Edis 4 problems
I got the car started and it seems to be running fine but, i cant get my tacho to work. I metered across pin 10 on the edis and ground and im getting +12v on pin 10 same thing on pin 12. I thought it was supposed to be a negative voltage from pins 10 and 12. Anyone throw me some pionters please.
posted on 24/11/07 at 04:15 PM Reply With Quote
Are you using this with Megajolt? If so, there are some solutions to the tacho problem on their site...
dave1888
posted on 24/11/07 at 04:21 PM Reply With Quote
Ive tried most of the wiring setups but to no avail. Im not even getting a rpm reading from the mjlj when connected to the puter. I think i might try to pick up a cheap tacho just to make sure the tachos not buggered.
tks
posted on 24/11/07 at 04:24 PM Reply With Quote
what you could try it so hook up a LED light with a resistor in light
if it blinks then the signal is there.
Tks
mangogrooveworkshop
posted on 24/11/07 at 05:26 PM Reply With Quote
dave i will get a spectrum analizer over to you in the next few daze
dave1888
posted on 24/11/07 at 07:33 PM Reply With Quote
I can upload and download maps to the mjlj and it shows 14 degree ignition advance but nothing in the other 2 lower boxes. I think its buggered
