Author: Subject: temperature sensor for a phase 1 Zetec.
Ian D
posted on 3/12/07 at 09:36 PM Reply With Quote
Guys,
On my silver top Zetec I have 2 sensors on the thermostat housing a small one below which I believe is the temp sensor and is connected to the Webber Alpha loom. On top is a much larger sensor with a 22mm thrread. to this I have connected my temp gauge. Unfortunately im getting no reading on the gauge. I have checked the wiring which is fine and if I short the wires the gauge reads fine. I believe this sensor is the fan sensor. Therefore is it digital, ie on or off?
If so shuould I tee my temp gauge wires to the lower sensorwhere the engine management connector is.
Ian
paulf
posted on 3/12/07 at 09:39 PM Reply With Quote
The large sensor on top is the ECU sensor and the smaller lower one is for the temp gauge.
Paul.
martin1973
posted on 3/12/07 at 09:51 PM Reply With Quote
also makesure to earth the temp sender if its a single wire jobby
martin
stevebubs
posted on 4/12/07 at 08:06 AM Reply With Quote
replace the sensor with one your gauge understands.
Get a 22mm blank plug from Think Auto and drill and tap it to take the standard gauge sensor.
