Author: Subject: Zetec alternator on silvertop
Blackwater
posted on 5/12/07 at 08:18 AM Reply With Quote
What alternators are you using on a silvertop Zetec 2.0, I think I have a -94 ?
I tried to search but found mainly blacktops
Any pictures on the belt routing would be great.
saigonij
posted on 5/12/07 at 09:47 AM Reply With Quote
i used the alternator that came with my donor engine. ( 1.8 ) with a new big fat cable from the battery to the alternator ( the weedy ones in the new loom were rubbish )
i then used a westfield alternator fitting kit that came with the bracket and belt.
prob a few pics in my archive.
UncleFista
posted on 5/12/07 at 11:27 AM Reply With Quote
We used a Nissan Micra alt, albeit with a new pulley welded on
ready to fit
ready to fit
Tony Bond / UncleFista
Blackwater
posted on 6/12/07 at 12:42 PM Reply With Quote
saigonij
I also got the tip about the WF bracket.
Thanks for the picture, it helps a lot. Are you also using the WF bracket?
What belt is that, do you have part number for it?
saigonij
posted on 6/12/07 at 01:11 PM Reply With Quote
yep, i brought the whole kit from Westfield. Its not cheap ( £60 ish ) but you get the bracket, the belt, bolts, nuts and the adjuster arm all in one pack.
here is a link to their online shop.
http://www.westfield-sportscars.co.uk/shop/product.asp?numRecordPosition=35&P_ID=286&strPageHistory=&strKeywords=&SearchFor=&PT_ID =78
you can also get the larger release bearing from them too.
