Big Stu
| posted on 12/10/03 at 08:44 PM |
Zetec alternator
hi,
I have fitted a zetec alternator, I was wondering how it is wired up. I thought that the two studs on the alternatoer mark B+ and d+ should be
connected to the positive of the battery, but there does not appear to be a connection for the no charge light... Any ideas, does the zetec not
require this???
One other issue will the alternator still generate the current if it is being turned the wrong direction, ie the opposite to the way it was
designed?
Stu
VinceGledhill
| posted on 13/10/03 at 11:44 AM |
I am not certain as to the wiring.... it's been a long time.... one of my two brain cells has died. The B+ is definately for the battery. I
presume the other comes from the ign light. Don't worry, you can try it and see if it works. You won't blow it up if it doesn't.
Ref turning one way or the other. Doesn't matter, but surely all engines go the same way??? If fitted to the other side of an engine it would
still go the same way.... anyway, it doesn't matter it will charge the battery whichever way it is turning.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Big Stu
| posted on 13/10/03 at 08:12 PM |
Cheers, I will try putting the D+ for the no charge light and see what happens. The reason the altenator is turning the wrong way is the altenator is
facing the wrong way.... Am I crazy??? could not find any other way of fitting it in.
VinceGledhill
| posted on 14/10/03 at 12:18 AM |
Brilliant Stu. Just love the image. Images are what we all see in our minds.... now that's an image.... brilliant. Never to be forgotten....
Can you get a better one of the mounting brackets.;-)
The wiring to the alternator via the light should go something like this....
Battery.... fuse box.... Ignition.... bulb.... alternator.... through alternator to earth via the rec.
When a pos feed is seen at the rec.... there is +12v "ish" at the back of the alternator and +12v"ish" at the other side which
is ultimately fed from the battery. Hence the bulb goes out.... 12v _12v = 0 v across the bulb. Savvy? No neither do I after 14 cans of Stella.
Regards
Vince Gledhill
