foes
posted on 23/1/08 at 08:52 PM |
Anyone used these L.E.D rear lights...?
Just wondering if anyone has used these led rear lights..?
lights
Agriv8
posted on 23/1/08 at 09:00 PM |
does not mention anything about an E mark
Regards
Agriv8
Mr Whippy
posted on 23/1/08 at 09:03 PM |
going by the picture, no markings on the lens so not SVA compatable
Howlor
posted on 23/1/08 at 09:10 PM |
One other bit to check is that technically for SVA / MOT the brake light needs to be a separate filament to the normal rear lights. With LED's
they are often the same LED just comes on brighter which is not allowed.
foes
posted on 23/1/08 at 09:13 PM |
cool, would they be ok post sva...?
what do you think of them?
Mark G
posted on 23/1/08 at 09:16 PM |
look alright but you'd need a seperate fog and reverse (if you have one).
caber
posted on 23/1/08 at 09:35 PM |
I think they look pretty cool. Rules on LEDs for brake lights seem to be a bit variable. There are a lot of Busses in Edinburgh with LED hamburger
lights where side and brake are the same LEDs. I thought SVA required that the tester is satisfied thatthe lights are as bright and visible as E
marked ones?
Caber
locoboy
posted on 23/1/08 at 11:01 PM |
IIRC you do not need to have an 'E' mark for SVA, but they need to meet the testers requirements in terms of brightness and radii etc.
An 'e' mark is just an easy way of telling that thet 'should' be ok for SVA.
Locoboy
speedyxjs
posted on 24/1/08 at 07:55 AM |
Dont know about SVA'ability but i have seen a few cars around with them and they look pretty cool. Better than the LED hamburger that busses
have imo
posted on 24/1/08 at 10:05 AM |
some of the buses round here have led lmaps - not sure if they are hamburger ones but the rear side lamp has some Leds (possible in a triangle
confuguration) on but when brakes are applied all LEDs in the circle come on.
t.j.
posted on 24/1/08 at 12:11 PM |
It's ADR (dangerous goods?). So no "E" or "e" would be sounding strange....
2b_pablo
posted on 24/1/08 at 01:55 PM |
I have them but havent fitted them yet.
seperate fog and reverse yes but had that anyway
foes
posted on 24/1/08 at 03:13 PM |
cool,could you post a pic up once fitted..?
cheers
2b_pablo
posted on 24/1/08 at 03:19 PM |
will do, might be a while tho the wing only got primed last night
