Author: Subject: sva or engineers report
jacko
posted on 28/1/08 at 08:55 PM Reply With Quote
My Son and I are putting a skyline engine gearbox .front and rear axles /suspension in a ford escort mk1
and would like to know if it needs a sva or engineers report .before it goes back on the road.
The shell is as ford made it but with a lot of added strength to take the power /bhp and weight thankyou
Jacko
meany
posted on 28/1/08 at 08:59 PM Reply With Quote
i would of thought engineers report for insurance purposes, but im no expert.
smart51
If the chassis / monocoque is unaltered then the vehicle doesn't neet an SVA. A simple MOT deems it to be road worthy and changes to the registration document makes it legal. It all depends on what additions you've made to the shell.
New brackets for the engine and running gear are probably OK as are, perhaps, seam welds to stiffen the shell up a bit. If you've welded big tubes into the shell you might be deemed to have altered the monocoque, in which case, book an SVA.
snapper
posted on 28/1/08 at 09:10 PM Reply With Quote
No SVA needed but an engineers report would probably be needed by the insurance company
[Edited on 28/1/08 by snapper]
I eat to survive
I drink to forget
onzarob
posted on 28/1/08 at 09:12 PM Reply With Quote
Do WRC Rally cars need an SVA then?
matt_claydon
posted on 28/1/08 at 09:30 PM Reply With Quote
I would have generally thought that adding structure is fine, it's alterations that remove parts of the original chassis that would make the vehicle need an SVA.
jacko
posted on 28/1/08 at 09:40 PM Reply With Quote
No alterations to chassis. flares to wheel arches and turrets in the boot for the suspension
hughjinjin
posted on 28/1/08 at 11:13 PM Reply With Quote
my understanding is that if the vehicle is more than 10 years old it doesn't need an sva
jono_misfit
posted on 29/1/08 at 12:13 AM Reply With Quote
Id speak to your insurance company and ask them. Usually need to get an engineers report if you've altered the structure.
I doubt a Mk1 would pass an SVA for sharp edges on everything etc.
russbost
posted on 29/1/08 at 08:06 AM Reply With Quote
I'd say as you've added structure not removed it an engineers report would be all that was necessary - sounds an EVIL machine BTW
smart51
posted on 29/1/08 at 10:22 AM Reply With Quote
Do they start off with road registered cars then modify them or do they get blank body shells from the factory then build from that?
I guess that if you ask 3 people from the DVLA, you'll get three answers. Pick the one that says "no".
posted on 29/1/08 at 12:46 PM Reply With Quote
Ring and ask your local DVLA.
Phil
