jabbahutt
posted on 30/1/08 at 02:55 PM |
joining 2 wires to 1
Afternoon all
I'm wiring in my rear lights and would like to clarify something. I've read the threads on soldering/crimping etc. but this is slightly
different.
I have 2 rear tail lights on each rear wing. Each has a +'ve and a -'ve. The loom is obviously only designed for 1 light unit so
I'm going to end up with two +'ve connecting to 1 on the loom.
What's the best crimping method as shoving two wires into a crimp designed for 1 seems a bit gash to be honest and my soldering isn't that
good and the wires are a bit awkward to get at so I think crimping is the way to go.
Any input on connector typres etc much appreciated as I'd rather spend a bit more money and do it properly than spend the rest of my days
chasing electrical faults that could of been avoided.
Cheers all
Nigel
indykid
posted on 30/1/08 at 02:59 PM |
2 wires into one crimp is used in all sorts of places on a factory equipment loom.
just make sure you use the right size crimp, and you shouldn't have any problem.
tom
posted on 30/1/08 at 03:22 PM |
yep - I second that.
I twist the two pairs for wires together then crimp - if your crimping technique is good, then there is no problem.
two laternatives is to use
a) bullet connector (4 way but you would use 3 ways).
b) 2 way spade
anotehr method is to connect one wire to the lamp and tap into it - carefully strip of a ring of insulation, wind the other wire around it and solder.
Cover with heat shrink and job done.
posted on 30/1/08 at 03:53 PM |
2 into 1 goes fine for crimping IMHO it's the best way to do it.
How's the car coming on Nigel - any progress pics?
jabbahutt
posted on 30/1/08 at 04:13 PM |
Hi Nick
Photos soon as long as I can get the thing out of the garage! the weather seems to know when I'm either going to spray paint or push the car
outside
caber
posted on 30/1/08 at 05:03 PM |
Scotchlok splice? These are insulation displacement things you close with a pair of pliers. They are fine for a take off for most things and can be
removed with minimal damage to original cable.
Caber
MkIndy7
posted on 30/1/08 at 05:40 PM |
Caber
*hang your head in shame sir!*
Them things ought to be banned.. I can't think of a place where somebody can excuse using one of those.. they are a complete and nasty bodge!.
Mark G
posted on 30/1/08 at 07:24 PM |
Hang on a min, They're fine unless its your own car, and then you should do it properly.
[Edited on 30/1/08 by Mark G]
posted on 30/1/08 at 08:40 PM |
Caber
Sotchlocks are ugly but effective --- I have never had a problem with one in service.
niceperson709
posted on 30/1/08 at 08:54 PM |
solder every joint and insulate with heat shrink tubing, it is the only way to reliably make any loon junction, especially it wet blighty
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
omega 24 v6
posted on 30/1/08 at 10:23 PM |
There was a time in our old regime that you'd've got the sack for using a scotchlock. I've seen many of them fail sometimes with
added consequences. I'm a big advocate of the heat shrink splice.
