Author: Subject: sierra starter motor wiring
nathanharris1987
posted on 12/2/08 at 04:25 PM Reply With Quote
my cvh starter motor wont play ball, is it schoolboy error or am i right in thinking the following;
The r on the right is the live and the br is earth? I was told that you could test it by hooking the live up to the battery and striking an earth to see if it turns?
Soz bout picture size by the way!
[Edited on 12/2/08 by nathanharris1987]
posted on 12/2/08 at 04:45 PM Reply With Quote
can't see your picture but most startes make earth via the body.
if yours has solenoid on, then there is fat wire for motro current and a lesser wire that goes to igntion barrel.
but since I am not familiar with pinto nor can see your photo, don't tkae it as given.
Slater
posted on 12/2/08 at 04:51 PM Reply With Quote
This thread might be useful
http://www.locostbuilders.co.uk/viewthread.php?tid=78802
Mr Whippy
posted on 12/2/08 at 04:55 PM Reply With Quote
Red wire to battery, earth cable to battery earth, small wire connected to live battery terminal will switch on motor
James
posted on 12/2/08 at 06:07 PM Reply With Quote
Holy Crap!
Could you not make the picture a bit bigger???
Macbeast
posted on 12/2/08 at 06:31 PM Reply With Quote
Cleaning and de-rusting the starter terminals might help too
matt_claydon
posted on 12/2/08 at 08:47 PM Reply With Quote
As above:
Large terminal = fat permanent live
Small terminal = switched live to activate solenoid and make starter run
Starter body = Ground
nathanharris1987
posted on 12/2/08 at 10:35 PM Reply With Quote
top bannana, i'll have a play first light tomorrow!
also im using lcb through a 1000 inch lcd tv so the pic is average size
ta guys
