StevieB
| posted on 13/2/08 at 06:33 PM |
R1 Loom Hazard Circuit
Would anyone happen to have a circuit diagram splicing a hazard circuit into an R1 loom.
StevieB
| posted on 13/2/08 at 07:04 PM |
Sadly, it's a 2000 model, otherwise that sounds nice and easy (did I metion I'm a numpty at electrics so haven't got much more than
the most basic of clues!)
StevieB
| posted on 13/2/08 at 07:48 PM |
That'd be great, cheers:
StevieB
| posted on 13/2/08 at 08:05 PM |
I'm retaining the bike switches and will probably use a durite hazard switch
StevieB
| posted on 13/2/08 at 08:17 PM |
I actually prefer those typoe switches - I think they look much smarter than the plastic things. I just assumed I couldn't use one of these
because I though it had to be illuminated in some way.
Where would I get the two live feeds from?
StevieB
| posted on 13/2/08 at 08:37 PM |
Cheers Chris, that's perfect.
| posted on 14/2/08 at 12:12 PM |
Steve,
if it's any use, we have a hazard wiring diagram (using a durite switch) on our website. It's on the Miscellaneous tab under
'Help'
Phil
StevieB
| posted on 14/2/08 at 05:16 PM |
Cheers Phil, I saw that (I've used you website as a reference for a lot of the build as the MK manual is poo to say the least - at least my
coffee doesn't stain my workbench though!).
The main problem I had with all the diagrams I've seen so far is that they all seem to be based around using a car or bespoke loom, where
I'm just extending my bike loom out and retaining the bike switches for simplicity/lightness
