locoboy
posted on 18/2/08 at 01:06 PM |
What battery tin top
Im after a new battery for my tin top and want to compare prices on the net.
My current battery has not got an Amps/hr rating on it or anything to tell me what spec it is.
Can anyone let me know what size in terms of cranking power i need for a 2.1 TD 406 estate 1998.
it also needs the right terminals on it and i cant find a listing of battery types for my car.
Locoboy
Mr Whippy
posted on 18/2/08 at 01:13 PM |
closest I could find is the 2.2 D - though that seems to be a common size for most of the engines.
I had a 406 2l petrol estate once as a company car, got 137mph out of it. I thought that was pretty quick for such a big car.
but on a private test track somewhere I can't remember where
Power : 62 AH
Cold Cranking : 580 CCA
Length : 210 mm
Width : 175 mm
Height : 190 mm
Weight : 16.4 Kg
[Edited on 18/2/08 by Mr Whippy]
iank
posted on 18/2/08 at 01:39 PM |
From http://www.varta-automotive.com/eng/index2.php?p=4&s=1&content=batteriesuche/searchApplication.html
Smallest is 556 400 048 3122
56AH 480A Cranking
Anonymous
posted on 18/2/08 at 04:40 PM |
Check your local motor factor they have an application list -- however should find a battery type number on it something like 075 or 096
Batteries come in two qualities --- basically the cheaper range have a shorter life and warranty. You get what you pay for, don't fit the
cheaper type unless you aim to sell the vehicle with 3 years.
Usual warnings about doing a charging voltage test and generals wiring check before condeming the battery.
[Edited on 18/2/08 by britishtrident]
posted on 18/2/08 at 04:59 PM |
it will be one of these
Type Cranking Amps (LxWxH)
096 675 amps 278 x 175 x 190
075 530 amps 242 x 175 x 175
027 500 amps 242 x 175 x 190
posted on 18/2/08 at 08:36 PM |
If its any help my Citroen XM uses the same engine and has a 096 battery
