Author: Subject: HElp help help help
pointy
posted on 22/2/08 at 07:17 PM Reply With Quote
HElp help help help
Gents,
I need help ref Tim electric temp gauge before I go and buy another one.
Story........
Built new dash, moved gauges, made note of wiring...all good so far.
When started the car gauge got hot and eventually the wires melted (live in and wire from sensor on engine) The sensor actually blew out the side of the engine (not the thread just the plastic insert...)
SO, got new sensor, Fitted it and rewired the gauge, then found the reason for getting hot was the fan belt had stopped the pulleys from turning as had slipped off and wedged itself . simple job..all fitted but the gauge still reads off the dial but not immediately however the car is not hot. ...SO...the question is can you burn the gauges out or are they robust....
Thanks for reading this and please reply.
Andy p
posted on 22/2/08 at 07:21 PM Reply With Quote
My first thought was - have you got a good earth between the engine and the chassis? That's often the cause of wires unexpectedly getting too hot - choke cables too! I'm talking about a proper braided earth strap.
Apart from that, check that you've got the wiring correct, the correct sensor, and so on.
[Edited on 22/2/08 by David Jenkins]
bonzoronnie
posted on 22/2/08 at 07:26 PM Reply With Quote
Faulty or incorrectly wired gauge.
Most unusal for the sender to self destruct due to minor overheating.
Did the engine boil over at all ?
Ronnie
Mr Whippy
were you meant to fit a resister?
posted on 22/2/08 at 07:31 PM Reply With Quote
...or a voltage regulator?
andrews_45
posted on 22/2/08 at 07:47 PM Reply With Quote
when i originally wired my gauges i wired mine all taking a voltage from one of the gauges. this caused one of them to pack up
pointy
posted on 22/2/08 at 07:56 PM Reply With Quote
Engine did not boil over and wiring correct.
Wiil just check my earth, but would have thought the gauge would not operate if not earthed???
No resistor originally
ANDY P
pointy
posted on 22/2/08 at 08:08 PM Reply With Quote
Gents
I owe you all a virtual pint.
earth lead not tight enough.
thanks again.
Off to cadwell sunday for a shakedown if readiness for the season.
Andy p
bonzoronnie
posted on 22/2/08 at 08:15 PM Reply With Quote
I think my money would be on a faulty gauge/sender.
If the engine never boiled over, i doubt the temp would hsve got high enought to damage the gauge.
As you say, the wiring was correct and the sender burnt out. Id have to suspect a faulty gauge.
Ronnie
EDIT, typed that before your last post.
Ronnie
[Edited on 22/2/08 by bonzoronnie]
It's really AMAZING what a bad earth can do!
Good result - well done! Have fun at Cadwell (I'm jealous...)
pointy
posted on 22/2/08 at 08:18 PM Reply With Quote
David,
Thanks again and by the way that green pillar drill I bought of you god knows how long ago is still chugging away...best thing I ever bought.
posted on 22/2/08 at 08:19 PM Reply With Quote
Ha! I didn't recognise the name!
Glad it's still going well.
