dan__wright
| posted on 25/2/08 at 11:44 AM |
front indicator extensions
anyone have any or know where i can get hold of some, just need them for a while before they fall off after sva.
will check the thread and let you know.
FREE THE ROADSTER ONE…!!
| posted on 25/2/08 at 11:48 AM |
I have a set of M8 threaded extensions I made for SVA. They're complete with drilled out bolts and black tubing to cover them.
Yours for free provided you pass them on when you're done.
U2U with your address if you want them.
[Edited on 25/2/08 by nick205]
| posted on 25/2/08 at 11:51 AM |
piccy...
| posted on 25/2/08 at 11:54 AM |
or do it like this so you can leave them on afterwards.
tegwin
| posted on 25/2/08 at 11:59 AM |
All I did was get a piece of round plastic electrical conduit and glue nuts in both ends...
Jobs a goodun...
Painted black they actually look really smart...
www.verticalhorizonsmedia.tv
scutter
| posted on 25/2/08 at 12:06 PM |
Dan, i have a set in Carterton you can borrow
Turned stainless steel with threaded ends and a side exit hole for the wiring.
  Pre sva 02
ATB Dan.
DaveFJ
| posted on 25/2/08 at 12:11 PM |
I had a spare pair of knackered indicators so I took off the rubber mountings complete with drilled out bolt and glued on a length of chromed tubing
from B&Q. glued in a suitable nut at the other end and screwed on my indicators... looks pretty good actually and I have ended up with extensions
that can easily be removed/refitted
Dave
smart51
| posted on 25/2/08 at 12:15 PM |
Mine are made from 15mm copper pipe with a brass nut soldered in at each end. 20mm round electrical conduit pipe is a nice snug fit over the top and
a bit of carbon effect sticky back plastic makes them look nice. So much so, I kept mine on.
worX
| posted on 25/2/08 at 12:33 PM |
I've got a pair that I made for mine.
They suit a pair of indicators from most Japanese bikes use. Think M8fine on ind. end and M8normal on inside.
I made my own as I wanted to use Motorbike indicators instead of the tiny aftermarket ones as I don't think they look that good on LSIS cars due
to the proportions of the other lights and front end etc.
If you want 'em, just drop me a U2U!
