hemibum
posted on 5/3/08 at 09:45 PM |
Wilwood Master Cylinder
Connected up the new tandem Aluminium Brake Master Cylinder today.
No fluid coming out of the rear "B" outlet.
Fronts have bled perfectly and have a great pedal with little travel, but obviously bugger all on the back.
Anyone experienced this before? Will be phoning Rally Design tomorrow, but thought I'd check if anyone else had come across this before.
Er, sorry, this seems to be on the wrong forum section. Maybe someone can move it?
[Edited on 5/3/08 by hemibum]
PAUL FISHER
posted on 6/3/08 at 07:09 AM |
Did you bleed the master cylinder up,before you started to bleed the brakes,I have a wilwood master cylinder on mine,I had to bleed the master
cylinder 1st,as per Wilwoods instructions,which tells you how to bleed the master cylinder before you attempt to bleed the brakes.I had the same
problem,but both front and rear would not bleed up,I then read the instructions ,so could be worth a try if you have not done it already.
hemibum
posted on 6/3/08 at 10:24 AM |
Thanks, there's no fluid coming out of the rear chamber at all. At the moment I've a rock hard brake pedal with the rear bleeder open!.
Just talked with Rally Design, they advise to remove the reservoir and see if there's any obstruction, if nothing seen then to return it.
