balidey
| posted on 6/3/08 at 08:32 PM |
Wiring a winch to power out and in?
I have a basic electric winch on my car trailer that I would like to re-wire, but I can't get my head around how to do it.
Its a simple 12v electric motor that drives the winch, with two wires to it. Currently no switch, just croc clip onto a battery and off it goes. To
reverse the direction there is a mechanical throw switch, or you can just swap the croc clips over.
But I have now acquired a nice 2 button switch with a coily cable (its a truck tail-lift wanderlead) that I would like to use to be able to press one
to power in, and the other to power out with no need to mess with the battery.
So, can someone please explain how I can do this? Wiring diagram or sketch would help my tiny brain understand
Thanks in advance,
EDIT: just to add the twin button switch has 'I think' 4 wires, but the switch can come apart if I need to bugger about inside that.
[Edited on 6/3/08 by balidey]
stuart_g
| posted on 6/3/08 at 09:11 PM |
without knowing how many terminals and hoe the switches are wired it is hard to comment how to wire these up.
Here is a simple diagram of a change over switch that will do what you want. Try to find how the switches you have work and use this
diagram.
owelly
| posted on 6/3/08 at 09:18 PM |
I would consider using the button box to operate two relays wired up to work as a DPDT switch. Or use a relay that is a DPDT and is heavy enough to
run the amps the winch will pull (!!).
http://www.ppcmag.co.uk
balidey
| posted on 7/3/08 at 08:28 AM |
Ah, yes of course. Thanks for the help, I now see its quite easy. Two buttons, two relays, two directions for the motor. Will give it a go at the
weekend.
