Author: Subject: battery cut off / Koso memory
Adam
posted on 12/3/08 at 01:09 PM Reply With Quote
Hello.
I need to fix a second security device for the SVA, i have a steering lock already. I was just wondering if i fitted a battery cut off switch would my koso loose all it's settings once the battery is disconnect????
Adam
Pdlewis
posted on 12/3/08 at 01:15 PM Reply With Quote
My Kosos worked fine with no power feed. I set it up then took it off for 3 weeks and it remembered all the settings
Mr Whippy
posted on 12/3/08 at 01:21 PM Reply With Quote
use can usually use a thin wire from the battery to keep radios alive etc, so long as its not wired to the starter and is obviously low amps, 3amp wire should do, with a fuse.
Schrodinger
posted on 12/3/08 at 01:31 PM Reply With Quote
Isn't the ignition switch and the steering lock all you need?
Keith
Aviemore
pewe
posted on 12/3/08 at 01:56 PM Reply With Quote
Ignition switch and steering lock are sufficient.
If fitting a battery cut-out IIRC you still need to be able to operate the sidelights or similar even when the battery switch is disconnected as parking lights. Also you may want to be able to operate the hazards when it's disconnected.
Cheers, Pewe
posted on 12/3/08 at 01:57 PM Reply With Quote
Put a 500 ohm resistors across the terminals of the master switch.
Adam
posted on 12/3/08 at 02:14 PM Reply With Quote
thanks for the reply guys. So am i right in thinking i don't need one. I'm using the original sierra ignition and steering lock?
Adam
tim windmill
posted on 12/3/08 at 03:03 PM Reply With Quote
Adam steering lock and ignition will pass sva no problem
tim windmill
posted on 12/3/08 at 03:04 PM Reply With Quote
can confirm disconnecting KOSO still keeps memory
Adam
posted on 12/3/08 at 03:16 PM Reply With Quote
Cheers Tim
Adam
