| posted on 1/4/08 at 12:35 PM |
FAO nitram38
Board is on its way.
In case you cannot decipher instructions, here they are again.
hmmm, photo not as good as I throught but on the right hand edge are labels:
12 V - this connects to battery positive terminal
OUT - this connects to LED - more below
0V - this connect to earth i.e. chassis or battery negative terminal
OUT terminal makes connection to earth so one side of your LED is connected to 12 V via a current limitingresistor - this will be inside the
lamp unit.
You can test circuit by connecting a 12 V LED e.g. maplins: 3mm 12V HE Red LED CJ66W 0.39p
Longer leg of LED goes to 12 V and shorter leg to OUT.
There are 3 pads on the board that you solder wires to - tin the wire then lay on top of the pad and apply soldering iron. Alternatively drill a 1 mm
hole from the sodler side and push tinned wire then solder.
To mount board make some plastic spacers with a slot cut part way through the thickness of the board and suppert on 4 sides, pu supports to where you
want it, maybe use a plastic cover from some tic tacs or similar to cover it.
To adjust the voltage at which the LED goes on/off there is a variable resistor - the black thing on the left. In the centre is a white plastic bit
with a cross slot that you turn with a small screw driver - it is preset to have the LED on when voltage is more than 12.5 V or so - turning it will
either increas/decrease threshold.
It has been tested on a lead-acid car battery and with a car battery charger.
Any Q. u2u me.
Hopefully it will work as well for you as it did for me.
locoboy
| posted on 1/4/08 at 12:40 PM |
Looks iunteresting but surely this can be kept to U2U only, to stop maybe pushing a more valuable (to more members)thread off the bottom of the front
page?
Just a suggestion.
Locoboy
nitram38
| posted on 1/4/08 at 12:41 PM |
This man is an absolute superstar!
Just to explain to those who don't know what the thread is about.
After I bought a Bright6 car version for my bec, I wanted to still use the battery indicator to show the state of charge.
(The N is taken care of via a gear indicator light.)
This locoster offered to make me a voltage sensing circuit that will still light my led battery indicator if the battery stops charging.
Now everyone will want one!
Thanks again
Martin
| posted on 1/4/08 at 12:50 PM |
page?
Just a suggestion.
you are correct but u2u does not have ablility to load photos.
worX
| posted on 1/4/08 at 01:10 PM |
yes it does
ps, I have no opinion whether this should be kept to U2U or not, just letting you know...
[Edited on 1/4/08 by worX]
| posted on 1/4/08 at 01:39 PM |
quote: Originally posted by worX
yes it does
ok then where is that option?
but clearly you do have an opinion as you replied!!
I know what you mean but this is probably first or second post that I have specifically directed at one person - WHOSE NAME APPEARS IN THE TITLE so
you shouldn't be looking!! and let's face it, IT IS HARLDY GOING TO BRING LOCOSTER FORUM TO ITS KNESS!
MikeR
| posted on 1/4/08 at 02:15 PM |
i think he's suggesting you put a link in the U2U to an image you load into your photo's section.
worX
| posted on 1/4/08 at 03:34 PM |
No I was suggesting that you just put the image tags round the photo just as they appear when you post normally.
Image tags are the letters img in the square brackets --> [ ] you put img in those square brackets at the start of the image URL and
then you put /img at the end of the image URL. The first img telling the code that this is a photo and the forward slash / with img telling the
code that this is the end of the photo.
And whether I have an opinion or not, it certainly wasn't a negative one.
Maybe I should of gone on to describe how to do it, but thought that may have caused offense. (Which, just in case I may have, is why I went back in
to say the not to offend edit...)
Clever cloggs
Oh and I need to get in touch with Fozzie as I never received your U2U!
| posted on 1/4/08 at 04:18 PM |
that isn't going to work is it?
the photi needs to be hosto somewhere; either done by uploading to photo archive or uploading via an attachment.
the photo is not hosted anywhere and u2u does not allow uploading.
I could of course have put it in my photo archive and use the img tags as you suggest but that is one more step that I did not want to spend time
doing.
anyway, that was my reason for not using u2u - the important thing is the info. got to the right person.
are we on page 2 yet?
[Edited on 1/4/08 by 02GF74]
russbost
| posted on 1/4/08 at 04:32 PM |
I thought the only way to put an image in a post was to upload it & put the image tags on, how have you loaded the above picture?
I might be more inclined to add pics if i didn't have to keep sticking them in my archive!!
| posted on 3/4/08 at 09:41 AM |
When you reply, or at least when I do , there is a box for Attachment: and either type in the jpg name or find it on your hard drive using
"browse". It does limit the size of pictures but saves a bit of time by not having to upload to photo archive, then having to link to it
in the post.
