Lee MacPherson
posted on 1/4/08 at 08:23 PM |
03 R1 wiring
Just started with my engine wiring on an 03 R1, can anyone give me some advice.
I think I have connected everything correctly.
1.I have the gearbox in neutral and checked the switch, when I connect the neutral switch I can hear a relay click in the starting circuit
relay.
2. I have wired up the enigine stop switch and this is closed.
The query I have is the two wires for the engine start as the wiring diagram shows them as Blue/White & Black, my connector has two black
wires.
Also I do not seem to have any life in the bike clocks, I have 2x 12v supplies and the negative is checking out OK.
Thanks.
Jubal
posted on 1/4/08 at 08:29 PM |
According to my wiring diagrams the start switch is two black wires. The US loom is black and blue/white.
Lee MacPherson
posted on 1/4/08 at 08:37 PM |
That agrees with what I thought, I have two balck wires which look like the start.
What am I missing ot get my engine to turn over. I have since read that I may need to link out the clutch switch is this correct.
Johneturbo
posted on 1/4/08 at 09:07 PM |
Try here, everything you need to get started
http://vortx.chockymonster.co.uk/content/view/36/69/
Lee MacPherson
posted on 1/4/08 at 10:01 PM |
Thanks for the info, I have everything connected as your instructions. I now think I may have a cyclelock and I am unsure which wires I need to
connect together. I have a 3-way and a 6-way connector------any advise ??????
fesycresy
posted on 2/4/08 at 08:16 AM |
Taken from speed8's archive and this is how I did mine:
cyclelock
HTH
Lyn
[Edited on 2/4/08 by fesycresy]
