Author: Subject: VDO Spedo and Sender problem
Agriv8
posted on 4/4/08 at 10:37 AM Reply With Quote
My spedo has never liked reading above 80 mph ( on the track of course ) and also had no problems passing SVA.
But when I got passed 80 the spedo would sudenly reads 1/2 the road speed This issue has finally got to the top of the list of things to sort.
I had 2 magnets on the Prop so I though increase this to 4 and it may solve the issue BUt alas No the spedo now only read to 30 mph ( estimated ) I have tried moving the sensor to 1mm and out as far as 3mm ( from the magnets. I have checked the setup and wiring to the guides on the ETB instruments site .
But I am unsure if I have a Hall affect Sensor or an Induction Sender ( anyone know how to tell the diference and if this could be the issue would magnets not work with either of them ?)
So over to you chaps for some further ideas.
Thanks in Advance
Agriv8
stevec
posted on 4/4/08 at 10:50 AM Reply With Quote
Inductive sensors usually have 2 wires, Hall effect have 3,
Steve.
posted on 4/4/08 at 10:57 AM Reply With Quote
How do wire a hall affect sensor where theres been an Inductive one please??
posted on 4/4/08 at 11:01 AM Reply With Quote
Do you have manual for this speedo?
What info. do you have about the sensor input to the speedo?
Obvioulsy all electronic speedo as programmable for number of pulses per mile or similar to allow for different sized wheels, diff ratios and number of magnets so you are setting this correctly?
Does the speedo read correctly but goes bonkers at 80 mph and above?
One of two possible things:
the speedo is not able to handle the pulses coming at it at high speed or the pulses are not right.
I would start off by testing the speedo itself by spinning a disc with magnet or similar fitted to a drill to provide pulses and see if speedo does read correctly.
if yes, then investigate the sensor.
posted on 4/4/08 at 11:02 AM Reply With Quote
Steve.
makes sense: positive power suply, negatvie power supply and sender output.
stevec
posted on 4/4/08 at 11:15 AM Reply With Quote
Steve.
Yep thats how I see it,
You get a square wave signal from a hall effect and a AC wave from an inductive.
Steve.
posted on 4/4/08 at 01:12 PM Reply With Quote
Steve.
Steve.
agree again, but the Hall would also give a non square wave, if it were not for the electronics magic inside that sends output to either max or min if the hall signal goes above/below a certain threshold.
Macbeast
posted on 5/4/08 at 07:47 PM Reply With Quote
Maybe if the speedo can't cope with the high pulse rate, the answer might be to run with only one magnet, not double them ?
posted on 6/4/08 at 09:18 PM Reply With Quote
there is another popssibilty and that is reed swtich in sensor.
these contain a small strip of metal that is attracted and bends to complete a cirtcuit when close to a magnetic - the repsonse time of these is very much greater than the other types so one would expect these to not workat high frequencies.
if you hold one of these to your ear and bring a magnet close by, you shold be ableto hear a tiny click.
