carpmart
| posted on 4/4/08 at 04:22 PM |
Wire sizes and theory?
Guys
If I have a piece of wire with a 1 mm core and another two pieces with a 0.5 mm core, if I ran current through the two pieces would it carry the same
amount as the single 1 mm core piece or not?
I hope that's as clear as your mums finest crystal?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Macbeast
| posted on 4/4/08 at 04:48 PM |
If you're talking cross-sectional area then yes. If you're talking diameter then no.
| posted on 4/4/08 at 05:52 PM |
technically yes, however there are subtle differences as the two 0.5mm cores will dissapate heat faster and thus stay slightly cooler with a lower
resistance. This is more important with fuse wires though, since temperaure is crucial. Hence why you arent meant to put multiple wires into a
rewirable fuse holder.
mark chandler
| posted on 4/4/08 at 10:10 PM |
No
two .5 wires will not carry anywhere near the same amount of current as a 1mm wire.
area of 2 x 0.5mm = 2.5sqmm
area of 1mm = 9sqmm
carpmart
| posted on 5/4/08 at 06:21 AM |
Thanks Guys - made me understand it better!
Harvey
'94 MX5 MK1, 1.8
