The Baron
| posted on 5/4/08 at 11:51 AM |
I think I have a short!!!
My battery seams to run down really quickly when the car is not used.
I have put a continuity meter across the two battery leads, with ignition off (key out) and I have a circuit, should I?
I disconnected the alternator, and the circuit was broken, is this correct, or is there a fault with my alternator?
B
NeilP
| posted on 5/4/08 at 12:08 PM |
Don't know what type of alternator your using but most regulators on them use diodes which (if frazzled) will leak charge in reverse - so could
be...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
