RickRick
| posted on 7/4/08 at 03:06 PM |
ECU mounting
So were has everyone mounted there ECU's it's an 04 R1 in a mnr. Are they waterproof? do they like to be kept nice and cool? i was
thinking about inside the passenger footwell but that makes it a bit tricky for access if i ever needed to get at it again
stuart_g
| posted on 7/4/08 at 03:33 PM |
Tha way my loom is fitted in the car my ECU is in the engine bay on the engine cradle. I haven't made anything to house it yet.
RickRick
| posted on 7/4/08 at 04:36 PM |
now that's somewere i would never have concidered mounting it. what part of the loom means you need to mount it there currently my loom has
all the lighting parts removed from it but it's still full length from the bike
snapper
| posted on 7/4/08 at 06:01 PM |
I like ECU's in the dry and the cool so have mounted on the firewall inside on the passenger side. I have MegaJolt and EDIS, the EDIS is next to
it as i found that the EDIS is known to fail if it gets to hot.
In a 7 it will get hotter in the engine bay than a Sierra.
I eat to survive
I drink to forget
iiyama
| posted on 7/4/08 at 07:14 PM |
Sorry mate but I cant think of a worse place to mount an ECU then over the engine and on the cradle. If the heat dont get it the vibration will!
[Edited on 7/4/08 by iiyama]
If its broke, fix it. If it aint broke, take it apart and find out how it works!
stuart_g
| posted on 7/4/08 at 07:43 PM |
It will be mounted in some anti vibration foam in some sort of box.
I don't actually think it is going to be a problem as in the R1 it is rigid mounted right on top of the engine below the airbox not under the
seat as on most bikes so it is subject to the same vibration and lots of heat. Where it is now it is actually cooler than in the bike.
[Edited on 7/4/08 by stuart_g]
stuart_g
| posted on 7/4/08 at 07:57 PM |
On the 05 R1 (not sure about 04) the ECU is under the airbox as stated in above post. The loom fitted better this way round with the connections for
the speed sensor, neutral switch, earth strap e.t.c at the back of the engine. I did originally want to have it on the scuttle beside the battery but
the loom didn't work out that way.
The wiring you can see cable tied to the engine cradle is the only wiring on show the rest of the ugly bits such as starter solenoid, relays e.t.c are
all on the inside of the car where they can not be seen.
