Author: Subject: Dead Alternator?
Worzey
posted on 13/4/08 at 12:48 PM Reply With Quote
Dead Alternator?
Numpty question time (electrics aren't a strong point).
I reported last week that my Rev counter was beating in time with indicators.
On a trip out yesterday the whole car died and wouldn't restart. After a tow home I put the spare battery on and it started first time so I assume the battery isn't wasn't charging as its a brand new Odyssey PC545.
Have checked the spare battery I have 12v across the terminals, but when the engine is running and with a few revs I expected this to rise to 13v-14V when the alternator kicked in?
It actually drops to 11.5v so I'm assuming the alternator is dead? The battery light wasn't on on the dashboard which is strange so could it be the regulator thats gone?
Caterham R400
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 13/4/08 at 12:58 PM Reply With Quote
was it a washout today ? might be going with a mates hybrid, TVR/ LOTUS
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
posted on 13/4/08 at 12:59 PM Reply With Quote
wrong thread
jollygreengiant
posted on 13/4/08 at 01:10 PM Reply With Quote
Yep sounds like alternator has gone to meet its maker, pushed up the daisies, joined the bleedin choir of jesabel. its ******* snuffed it, If it hadnt been bolted to the engine it would have fallen off weeks ago.
Oh sorry a bit of Monty P slipped in their.
Yes an alternator should produce about 13v (+/_ 1V) when the engine is revved. It should also maintain the voltage with ALL your lights, hazards, heaters etc switched on at the same time.
posted on 13/4/08 at 01:25 PM Reply With Quote
lovely plumage.
Worzey
posted on 13/4/08 at 01:53 PM Reply With Quote
Cheers! I thought it might be stunned or maybe pining for the fjords but its sounds like its an ex alternator. Oh bum!
"VOOM"?!? Mate, this alternator wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
This could be expensive
Caterham R400
Worzey
posted on 13/4/08 at 01:58 PM Reply With Quote
Can anyone tell me if the alternator for the 20v 4AGE is the same as for the 16v 4AGE or if I have any alternative lightweight options that fit the existing mountings?
Caterham R400
posted on 13/4/08 at 02:07 PM Reply With Quote
Sounds like the original cause was a bad earth or arcing connection --- either will kill an alternator.
Check all the connections & earth points very carefully especially the connections at the alternator itself.
Litemoth
posted on 13/4/08 at 04:09 PM Reply With Quote
Had a similar issue with my 4A-GE. Turned out that the B+ connection was touching the steering column when the engine was tensing on it's mounts. It had blown a fuse but of course no light on dashboard because the alternator was still functioning, just not connected to the battery any longer.
Dusty
posted on 13/4/08 at 06:59 PM Reply With Quote
If you get no ignition light when switching on it may be a blown bulb. Depending on what alternator you are using you should first check it's ignition light circuit and or it's switched live supply. Most alternators have one or both of these and need this excitatory current to be able to produce lectric.
