Author: Subject: Cant get my brake lights to work.....
peterparsons
posted on 16/4/08 at 12:28 PM Reply With Quote
Hi all, As above...
I have an inline pressure switch which is fitted into the line to the rear brakes.
When I push the brake pedal, nothing happens.
If I join the two wires together the lights come on.
Any ideas / do the switches come at different pressure settings ?
Any advice is more than welcome..
Yes, I've blead the system and the switch is mounted horizontal.
[Edited on 16/4/08 by peterparsons]
mackei23b
posted on 16/4/08 at 12:30 PM Reply With Quote
Do you have pressure in the rear line, i.e do your rear brakes work?
If yes then I would suspect it's the switch.
Ian
mookaloid
posted on 16/4/08 at 12:32 PM Reply With Quote
Daft question, but you have bled your brakes haven't you?
mark
iank
posted on 16/4/08 at 12:37 PM Reply With Quote
Another possible problem is if you've mounted the switch with the wires vertical and there is a bubble trapped between the switch and the fluid.
[Edited on 16/4/08 by iank]
Anonymous
jos
posted on 16/4/08 at 12:40 PM Reply With Quote
If youve got a bias valve in the line to the rear then the rear brakes will only operate when the bias valve tells them to
This is why the brake light switch is normally put in the line(s) to the front brakes so that the pressure increase when you press the brake pedal makes the contact to operate the brake lights.
The rear brakes dont always work or do alot when they are working
DarrenW
posted on 16/4/08 at 12:59 PM Reply With Quote
My brakes work good. Pressure switch is in rear line. Brake lights dont operate until i really push the pedal hard (ie hardly ever on the road). My research so far suggests rear line doesnt see sufficient pressure to make such switches work.
Option 1 - try as Jos says. However it may be possible that such light cars need light operation of stop pedal so whilst this should work it may not be 100%.
Option 2 - my investigations have shown that S2 non servo'd land rovers had the exact same issue yonks ago and a lower pressure switch was made available for them. Im awaiting one at the mo. Will report back when its fitted and tested. I think my mate is getting it from Britpart (he is a britpart dealer).
Strange that some people never have a problem yet others do. There must be a wide tolerance band in the switches or there are 2 types that are sold as the same part. I cant remember what the type number was on mine.
posted on 16/4/08 at 01:13 PM Reply With Quote
why should that make a difference - air transmits pressure too.
clearly either the switch is faulty or there is not enough pressure for it too operate.
Paul TigerB6
posted on 16/4/08 at 01:17 PM Reply With Quote
I've had a hydraulic switch fail on me in the past. Simplest solution was to leave it in situ to save bleeding the brakes and replace it with a microswitch from maplins mounted on a bracket near the brake pedal.
If you have a multimeter then check for continuity across the contacts of the switch when the pedal is pressed.
iank
So you don't bother to bleed your brakes, or indeed put any fluid in to start with?
Anonymous
posted on 16/4/08 at 02:26 PM Reply With Quote
I do bleed them in order for them to operate at maximum efficiency. They will work with air but some of the pedal movement will result in compressing the air so there is less travel for the pistons - with too much air the pedal will bottom out.
Mr Whippy
posted on 16/4/08 at 02:32 PM Reply With Quote
the pressure switch used on aircooled vw's works at very low pressures and requires the lightest of touches to switch it on.
posted on 16/4/08 at 02:38 PM Reply With Quote
There are two types of readily available switches 5psi and the other is much higher.
If enough air is trapped in the switch the switch wil not bne made and lights will not work. Air compresses readily, hydraulic fluid does not (by design).
Turn the switch on it's side - Un-nip the nut housing the switch - depress the brake pedal until fluid is expelled under pressure. Nip up the nut. This should fix it if the switch is ok.
peterparsons
posted on 16/4/08 at 03:08 PM Reply With Quote
YES - i have blead the system
YES - the switch is mounted Horizontal
Sounds like I either need to move the switch to the front pipes or find a lighter setting switch - any ideas from what car ?
Paul TigerB6
posted on 16/4/08 at 03:39 PM Reply With Quote
Personally i'd suggest the hydraulic switch would be far better being left in situ and replaced with a much more reliable and easily replaced electrical microswitch. Saves all the hastle of rebleeding the whole system if its working well, and is very easy to adjust to light up the brakes when the brakes are actually activated simply by moving the bracket.
jacko
posted on 16/4/08 at 03:43 PM Reply With Quote
Thats what i did
DarrenW
posted on 16/4/08 at 03:46 PM Reply With Quote
Have to say the idea of a microswitch is far more tempting. Isnt it a shame the maser cylinders didnt have the piston end sticking out so switch could be added there. I can access pedal area but i need triple jointed elbows and invisible hands o reach and see what im doing. Fitting brackets is more tricky unless there are easier switches to use.
darrens
posted on 16/4/08 at 05:14 PM Reply With Quote
I thought brake line pressure switches should ALWAYS be mounted inline on the the front system as the front is what doing the most braking and hence the greater amount of pressure.
Ta
[Edited on 16/4/08 by darrens]
Canada EH!
posted on 16/4/08 at 07:01 PM Reply With Quote
Best bet is an electric switch activated by pedal movement, so the slightest touch brings on the lights to let the lorry driver know you may be about to stop, also handy when racing as a touch of the brake pedal and a wave of the arm may get the competitor behind to pass and go too deep into the corner while you are still on the loud pedal, one of our locals was well known for this, caught the new guys every time.
