tjoh84
posted on 24/4/08 at 10:17 PM |
savage swiths how to light up
hi i have savage switchs fitted in my car but they dont light up bllue they work thought what do i need to do for them to light up
worX
posted on 24/4/08 at 10:23 PM |
You need to take a "trigger" switching live from something.
Most people use the Output from the Savage switch for the Sidelights.
The output is usually Pin 2.
Just make a loop from Pin 2 Sidelights to the +ve side of the centre (illumination) of the switch. And then Loop to the other +ve centre 2.5mm
terminals.
You then need an earth to the -ve side.
You should be able to just do a similar loop to all the -ve terminals in the centre and then join it to a decent chassis earth.
It is all realatively simple and should only take you about 30 mins max.
Give me a shout Terry (U2U) if you have any probs, I'd be happy to help mate.
tjoh84
posted on 24/4/08 at 10:30 PM |
think i will leave that alone i will stick to bathroom fitter and leave car elecs alone
worX
posted on 24/4/08 at 10:40 PM |
If you are struggling mate, then take a quick snap of the dash (front and back) and I will make you a small loom up so all you need to do is plug it
in! No worries at all!
I'll include some destructions for it too if you would like, so you won't get anything in the wrong place...
Let me know if you are interested, it wouldn't be any trouble mate!
Edit - Actually, just a photo of the front will be enough!
[Edited on 24/4/08 by worX]
welderman
posted on 24/4/08 at 10:45 PM |
he's doing mine first
Thank's, Joe
I don't stalk people
worX
posted on 24/4/08 at 10:48 PM |
Yes, but yours is 45 miles away and I don't have a car for a couple of weeks, I can make Terry's in about 5 mins and post it to him!
I'll hopefully do your Dash tomorrow night!
I've got Derek's (Jubal) here too! So he'll prob tell me off aswell as you!
tjoh84
posted on 24/4/08 at 10:49 PM |
cool ok i will send you pics next weekend as away this weekend cheers for that
welderman
posted on 24/4/08 at 10:50 PM |
yes but no but, i can come and pick it up, i have car that will start.
you will get a top job mate, Steve is the Guru.
[Edited on 24/4/08 by welderman]
Thank's, Joe
worX
posted on 24/4/08 at 10:57 PM |
No worries mate!
DarrenW
posted on 25/4/08 at 09:27 AM |
Lighting up the svages is simple by taking feed from sidelight circuit then connecting to each o fthe switches.
For the hazard - i found my digidash indicator warning lamps dont work when ignition is off. I wired up the hazard switch light so it flashed when
hazards are on. Had to take feed from indicators via diodes. Must remember where i put the wiring diagram for that. Mave was asking for it yesterday.
