Author: Subject: indicator speed challenges
Steve Lovelock
posted on 29/4/08 at 09:15 PM Reply With Quote
My indicators are quite fast and I am not sure what to do about it.
I am running LED rear indicators with a resistor in line as supplied by Europa. I have a side repeator light and a set of front indicators running with 21W bulbs.
Should I consider switching the side repeator bulbs to 21W as well?
Any other suggestions?
Regards
Jon Ison
posted on 29/4/08 at 09:24 PM Reply With Quote
You can get a led flasher unit, not expensive, search fleabay.
Jon Ison
posted on 29/4/08 at 09:27 PM Reply With Quote
like this
fixed the same problem for me, ditch the resistors too.
redscamp
posted on 29/4/08 at 09:28 PM Reply With Quote
you might like to try ebay item
3 Pin Electronic LED Flasher/Blinker Flash Signal Fix Item number: 250239121302
goes at same speed regardless of load.
(the + and _ blades are the wrong way round for a ford so the wires need swaped)
RazMan
posted on 29/4/08 at 09:31 PM Reply With Quote
Definitely ditch the resistors as they are a potential fire hazard.
LED flasher is the proper way to do it but watch the loading - some will only allow 21W ie one filament bulb in circuit.
You could always convert to LED lights all round
Raz
Steve Lovelock
posted on 29/4/08 at 10:15 PM Reply With Quote
Thanks guys. So to get this straight, I ditch the resistor (which cost more than the new relay!) and buy the new LED relay. This will power my LED rear indicators, 5W repeators and 21W front indicators.
Or am I missing something?
RazMan
posted on 29/4/08 at 10:21 PM Reply With Quote
That is basically right Steve. I am amazed at how many people still insist on using ballast resistors, when changing the relay is cheaper and consumes less power. The resistor can only be considered as a temporary solution as it is really just an electrical bodge - any light supplier worth his salt should not recommend them and simply supply the correct flasher unit for the job.
[Edited on 30-4-08 by RazMan]
Raz
Steve Lovelock
posted on 29/4/08 at 10:26 PM Reply With Quote
I did it because the light supplier recommended it, a little annoying though.
iiyama
posted on 30/4/08 at 06:50 AM Reply With Quote
Light supplier recommended them to me as well. Just as a point of fact though, the resistor dosent fit in series, it fits in parallel. Do that and the flashing issue will be resolved.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
posted on 30/4/08 at 09:14 AM Reply With Quote
That was your mistake. You should have asked the question on here and would have saved a few quid.
It is extremely rare for a question or problem posted on here not to be answered or resolved.
So keep up the good work chaps!!
Carry on.
Steve Lovelock
posted on 30/4/08 at 12:27 PM Reply With Quote
Will having the resistor in parallel really work?
RazMan
posted on 30/4/08 at 01:01 PM Reply With Quote
The purpose of the resistor is to force the LED light to appear to draw the same current as a filament bulb (~2 Amps) which allows the bimetal flasher relay to flash at the required rate. As the LED only draws a fraction of this current, the resistor is connected in parallel to the LED unit and dissipates the extra current in heat. If the resistor is too small, it can overheat, especially if the indicator is left on for any length of time (ie hazards) which is why it is not a good idea.
The correct flasher unit does not depend on such high loading and the flash rate is generated electronically, consuming very little power.
Raz
Steve @ sVc
posted on 8/5/08 at 02:50 PM Reply With Quote
How have you wired up the resistor??
Bet Europa didn't tell you.
Regards
Steve @ sVc
iiyama
posted on 8/5/08 at 04:42 PM Reply With Quote
Attatch one end of the resistor to one tail from the light, then the other end goes to the other tail.
edited to say your not looking for the above answer!!! ooops!
[Edited on 8/5/08 by iiyama]
