Author: Subject: how do you wire up a facet pump
ditchlewis
posted on 1/5/08 at 09:27 PM Reply With Quote
Just bought a Red Top facet fuel pump (thanks Doofus), and an inertia switch (thanks Ebay)
the pump has one cable comming out of it and no further terminals, so i assume that the cable is for a power supply which will be from the ignition to the inertia switch to the pump, while earth is through the body of the pump. am i correct?
ditch
mark chandler
posted on 1/5/08 at 11:49 PM Reply With Quote
Yes, body is earth, best positioned with the filter end down.
These are also pretty powerfull so expect carb flooding issues unless you plumb a return or use something to regulate the flow.
Regards Mark
snapper
posted on 2/5/08 at 06:07 AM Reply With Quote
The Facet fitting kit shows a small earht cable to bridge from the pump body past the mounting rubbers to body/earth.
Power wire goes to inertia switch then onto ignition barrel or seperate switch.
I eat to survive
I drink to forget
snapper
posted on 2/5/08 at 06:10 AM Reply With Quote
I have a Malpassi Filter King regulator at the carb end without this the fuel just leaked out, overpowering the float valves in the carbs.
I eat to survive
I drink to forget
ditchlewis
posted on 2/5/08 at 06:55 AM Reply With Quote
I've got a filterking pressure regulator to plumbing to. this time i will put it between the pump and the carbs, not before the pump
what sort of power requirement do these pumps require amp wise? i know it's 12V
ditch
[Edited on 2/5/08 by ditchlewis]
posted on 2/5/08 at 07:48 AM Reply With Quote
I have a Facet 'solid state' fuel pump (the small one) and the instructions recommended a 3A or 5A fuse.
Can't imagine that yours will be much different, even though it's bigger.
