Poll: Which is best for ignition leads [View Results]
Carbon core
Copper core
Author: Subject: Which is best for ignition leads
Snuggs
posted on 2/5/08 at 09:39 PM Reply With Quote
Gonna get some new leads made up but cant decide which type
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
dave r
posted on 3/5/08 at 07:29 AM Reply With Quote
depends what your using with them
old fashoined points, copper everytime (as long as you aint got a radio!!)
newer electronic systems can suffer with interference from the ignition when using copper
turbodisplay
posted on 3/5/08 at 08:12 AM Reply With Quote
Carbon core is designed to suppress the noise.
In PPC mag an emerald ecu failed to opperate correctly due to copper cores causing electrical noise.
There is some very low loss cores made from a metal core but it is wound to supress noise. Magnacore?
I have cabon core cable plugs using an edis sustem, and the sparks are healthy enought, will have to see what its like on boost.
Darren
Snuggs
posted on 5/5/08 at 08:39 PM Reply With Quote
Thanks for the replies.
As I am using Megajolt I am getting a set of carbon leads made up by these guys. www.formulapowerleads.co.uk
Saw them at Stoneleigh and the looked very well made.
Clive
