Mr Whippy
posted on 7/5/08 at 01:38 PM |
Age for Hazards
Lots of questions from me recently and here’s another can anyone remember the age a car needs to be before it is required to have hazard lights,
I'd rather not bother with them.
nothing to do with the SVA test, just an MOT.
posted on 7/5/08 at 01:43 PM |
around 1980..... will go a quick google
close but .....
Vehicles first used before 1 April 1986
A hazard warning device is not required by Regulation, but, if one is fitted, it must be tested.
The hazard warning lamp 'tell tale' may be a separate light or the same as the indicator 'tell-tale. However, it must be a flashing
light.
so after 1st April 1986 compulsory.
[Edited on 7/5/08 by 02GF74]
Mr Whippy
posted on 7/5/08 at 01:48 PM |
cheers, I'll check the log book
posted on 7/5/08 at 01:57 PM |
quote is from MOT UK ... interesting bit is the "used"....
My ex MOD Landy was made in 1975 and registered after release in 1980; MOT place wanted to fail it over the hazards which as we can see above does not
apply; thiuer mistake but no harm done as I shoved the papaers under their noses
Now let's say it was registered in 1987 - how does the "used" bit apply in that situation?
Mr Whippy
posted on 7/5/08 at 02:08 PM |
I think that refers to like say a vintage car (a pre-war barn find for example) that had no registration documents but you could prove was
'used' previously before 1986 as I'm sure they're would be too many issues that it would be imposable to comply with modern
regulations.
One car in the local Museum was literally dug out the ground after being burred for something like 30 years and is now used on the road!
[Edited on 7/5/08 by Mr Whippy]
